adorado3
Jul 22, 2020Aspirant
Slow WiFi R6100
I am having issues with my wifi speeds. I am currently paying for 100MBPS and I am only getting 6 upload and 3 download.
Router Model: R6100
Firmwear Version: V1.0.1.22
I need to know where to start to fix this issue.
lets first start with what gateway/modem you're using?
The speeds you're getting, are they wired or wireless? And if wireless, are they on the 2.4ghz band or 5ghz band?
Have you direct connected to the modem/gateway and tested its speeds? if so, what are they?
- adorado3Aspirant
I am using MOdem Model R6100.
These are wireless speeds on the 5ghz.
a direct connection gives me between 98-100MBPS.
The R6100 is the router. Not the modem or gateway.
What firmware is on it?
What have you done to try and fix the problem? (factory reset, enable ipv6, etc)
