trruckersmom's avatar
trruckersmom
Slow wifi signal since modem switch
Good Morning, My WNDR3400v3 Has been functioning fine until 3days ago since I purchased it 1 1/2 yrs ago . My issue now is it isn't putting out like it was. Speed test are really different. (Dramatic ...
  • DexterJB's avatar
    DexterJB
    Feb 08, 2018
    Hi trruckersmom,
    Are you still experiencing the issue?
    If yes:
    1. Have tried resetting the router after the update?
    2. What is the exact firmware version of the router?
    3. What speed are you getting wired from the router?
    4. What speed are you getting wired from the ISP's modem?
    Dexter
    Community Team
