trruckersmom
Dec 13, 2017Aspirant
Slow wifi signal since modem switch
Good Morning, My WNDR3400v3 Has been functioning fine until 3days ago since I purchased it 1 1/2 yrs ago . My issue now is it isn't putting out like it was. Speed test are really different. (Dramatic ...
- Feb 08, 2018
Hi trruckersmom,
Are you still experiencing the issue?
If yes:
1. Have tried resetting the router after the update?
2. What is the exact firmware version of the router?
3. What speed are you getting wired from the router?
4. What speed are you getting wired from the ISP's modem?
Dexter
Community Team
trruckersmom
Jan 02, 2018Aspirant
William10a, Could this be a part of my issue?
WNDR3400v3-intermittently-drops-connection-to-internet/m-p/1472936#M67429
WNDR3400v3 - intermittently drops connection to internet
Have had this router a while now without any problems whatsoever. Since purchasing a smart TV, the modem has been dropping the connection at random intervals. Tried firmware update - no improvement. The only other thread I found about this mentions that the device might need restarting with 'heavy usage'. The device has now been restarted 50 more times in the past few weeks than the entire year before it. So, is this alleged heavy usage the likely culprit? If so, is a new router the only solution?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 1
Labels:
Troubleshooting
Tags (0)
Add tags
DexterJB
Feb 08, 2018NETGEAR Moderator
Hi trruckersmom,
If yes:
Dexter
Community Team
