Carl11
Feb 26, 2021Follower
Slow wifi speeds
Hello,
I live in the UK and have one gigabyte broadband with Virgin Media.My RBR850 - Orbi Tri-band Mesh WiFi 6 Router(RBR850) is plugged into the Virgin Hub 4. I have one Orbi satellite upstairs. My laptop is a MacBook Pro with these specs: 802.11 a/b/g/n/ac.
This is what happens when I test the speeds with no other devices on the network:
When connected to the Hub 4 or the Orbi base station by an ethernet cable, I regulary get over 900Mbs of broadband. But when I hop on wifi, sitting two feet from the base station, the rate falls to between 200Mbs and 450Mbs.
I get the same numbers when I run the same two tests (Ethernet vs wifi) using the Orbi satellite upstairs.
But whenever I check the Orbi app it says that my MacBook is connected at a Link Rate of 975Mbps. (I'm using my iPhone 7 to check. At the time of checking there are then obviously two devices connected to the Orbi mesh network. The app says the iPhone is connecting at 875Mbs.)
What's going on here? Shouldn't I be getting more or less the same bit rate via Ethernet and wifi? Especially standing so close the Orbis?
Thanks for your help!
Carl
1 Reply
Wifi won't hit the same speeds as wired.
there's more network overhead, interference, and device limitations over wifi.
But wired doesn't have those same issues.
So the wired/wireless speeds are an expectation. you can read more about it here:
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
seems a little off for the mac to have a 975mbps link rate as the RBR50 has a 866mbps fronthaul (link connection)
