tbardes
Sep 24, 2020Aspirant
Slow WiFi WNDR3700
So, I've had this N600 router for a while and also have an EX6150v2 AC1200 WiFi Range Extender connected to it. Today I upgraded my ISP service from 100MBPS to 400MBPS and am getting about 250MBP...
- Sep 25, 2020
I'd look at one of the triband orbi setups. With your router being in the basement on 1 side of the home, you're limiting your coverage. the orbis would allow you to keep the router there and place 1 or 2 satellites as needed throughout the home.
You'd be best off if you could find a way to centrally locate the router. You might be find with just 1 router if you could centrally locate it.
only thing to keep in mind is the limiting factor of wireless is usually the device you're using. Most phones/tablets/pc's only have a 1x1 or 2x2 antenna setup.
tbardes
Sep 25, 2020Aspirant
Thanks Plemans. Any recommendations for what to look for capability-wise, considering I could have 3 iPhones, 2 laptops, 2 smart TVs connected simultaneously via WiFi plus a hardwired laptop, worst case scenario?
Sep 25, 2020Guru - Experienced User
how big is your home and what materials are the interior walls?
how many levels?
Depending on the size, I'm a fan of mesh networks like the triband orbi's (not the dual band ones)
but if it isn't to large, a solid gigabit AC router could work as well.
And sadly it also comes to budget. Playing worse case I can point to some expensive routers :)
- tbardesSep 25, 2020Aspirant
Thanks for the fast reply! Here are some details:
Home is about 2200 Square Feet. Modem and router are located in the basement/cellar due to the fact that that is where my office is and that is the one wired connection. Wireless is needed on first and second floors. Interior walls are wood and wallboard - no metal studs or anything like that. There is no gaming but we do stream Netflix, etc. accross a number of devices on the first and second floors.
I'm not looking to spend a small fortune but I'm also not looking for the bare minimum. Ideally, I would like to take advantage of as much of my 400MBPS from my ISP as possible both wired and WiFi.
