sauronet's avatar
sauronet
Slow WiFi
Hi Guys!
From few days I have a problem with slow Wireless connection on my R6400.
Generally my provider deliver 250Mb/s download and 20Mb/s upload, but I have on Wifi always almost 30/20Mb/s, but on cable I have maximum what my provider delivers.
It's interesting, that download speed is very regular (even if I'm 5-10 meters from router) and vary fast reaches 30Mb/s (on speedtest.net). It looks like some limit.
My settings:
Firmware Version: 1.0.1.24
MTU - 1500 and it is OK (tested)
WMI - disabled
QoS - disabled
I also tried factory reset - no change.
I greet and count on help!
  • It was FM! When I downgraded it to V1.0.1.22_1.0.17 problem has been solved!
  • It takes two to tango. What device are you using to test? And are you connecting on the 5 GHz or 2.4 GHz band?
