pkliot
Nov 23, 2022Aspirant
Slow Wired Connection AC1200 R6230
I recently had AT&T fiber installed and I now have roughly 980 mbps coming from my AT&T modem if I directly connect my computer to the modem. If I connect the AT&T modem to my R3230 router and connec...
michaelkenward
Nov 24, 2022Guru - Experienced User
plemans wrote:
do you have the R6230 in AP mode?
Or the R6230's ip address put into the att gateway's DMZ?
Otherwise you're in a double nat
Do all AT&T modems do that?
No option for "bridge mode"?
Dontcha hate these ISPs?
ATT pretty much forces all its users to have a gateway that's not just a modem. A bit sad you can't just get a modem from them.
- michaelkenwardNov 24, 2022Guru - Experienced User
Sad, and a bloody nuisance.
BT does that in the UK, but with its VDSL service I can use my own modem, although they are getting harder to find now that Netgear has stopped making them.
That's what you get when you have to rely on old technology.
The good thing about fibre and the use of the Optical Network Terminator (ONT) is that they don't seem to come in these omnibus devices.
Maybe pkliot should confirm that AT&T has forced them down that route.
