pkliot
Nov 23, 2022Aspirant
Slow Wired Connection AC1200 R6230
I recently had AT&T fiber installed and I now have roughly 980 mbps coming from my AT&T modem if I directly connect my computer to the modem. If I connect the AT&T modem to my R3230 router and connec...
Nov 24, 2022Guru - Experienced User
do you have the R6230 in AP mode?
Or the R6230's ip address put into the att gateway's DMZ?
Otherwise you're in a double nat
pkliot
Nov 24, 2022Aspirant
Thank you for your response,
I didn't put it in AP mode, I'll put the IP into the DMZ when I get back to work and see if that fixes the problem.
