m_cstilly
Sep 19, 2016Aspirant
Slow wired connections
I have a WNR2000v4 connected to an 8channel, DOCSIS 3 surfboard modem hooked directly into my cable provider. My desktop sits right by the modem and router, so I have it wired into the router instead...
- Sep 21, 2016
So the hardware functions at speed less a reasonable amount of overhead when used as a switch. When operating as advertised the overhead is >50%. It's not under warrenty because Netgear's warranty and customer service periods are way below par for industry standard. I guess I'll be replacing it with a competitor's brand. I'm looking at upgrading it with a much nicer Linksys model.
netwrks
Sep 19, 2016Master
Your router ports are 10/100 Mbps LAN and WAN. Either upgrade your router, or downgrade your internet. Also, you router is End OF Life...
http://www.downloads.netgear.com/files/GDC/datasheet/en/WNR2000v5.pdf?cid=wmt_netgear_organic
- m_cstillySep 19, 2016Aspirant
Are you saying a 10/100 router is incapable of 100Mbps? Or even 50Mbps?
