m_cstilly
Sep 19, 2016Aspirant
Slow wired connections
I have a WNR2000v4 connected to an 8channel, DOCSIS 3 surfboard modem hooked directly into my cable provider. My desktop sits right by the modem and router, so I have it wired into the router instead...
- Sep 21, 2016
So the hardware functions at speed less a reasonable amount of overhead when used as a switch. When operating as advertised the overhead is >50%. It's not under warrenty because Netgear's warranty and customer service periods are way below par for industry standard. I guess I'll be replacing it with a competitor's brand. I'm looking at upgrading it with a much nicer Linksys model.
m_cstilly
Are you saying a 10/100 router is incapable of 100Mbps? Or even 50Mbps?
netwrks
Sep 19, 2016Master
It should at 50Mbps, but not 100, as there is bandwidth overhead. Have you changed the Ethernet cable between router and modem?
- m_cstillySep 19, 2016Aspirant
Yes, I upgraded the ethernet cables from both the modem to the router and the router to the pc.
- ElaineMSep 20, 2016NETGEAR Employee Retired
m_cstilly How about if you connect your modem and desktop to the LAN ports on the router and see if you'll get the same speed when you connect directly to the modem.
- m_cstillySep 20, 2016Aspirant
Connecting the modem to one of the lan ports does not allow the router to connect to the internet.
