m_cstilly's avatar
m_cstilly
Slow wired connections
I have a WNR2000v4 connected to an 8channel, DOCSIS 3 surfboard modem hooked directly into my cable provider. My desktop sits right by the modem and router, so I have it wired into the router instead...
  • m_cstilly's avatar
    m_cstilly
    Sep 21, 2016
    So the hardware functions at speed less a reasonable amount of overhead when used as a switch. When operating as advertised the overhead is >50%. It's not under warrenty because Netgear's warranty and customer service periods are way below par for industry standard. I guess I'll be replacing it with a competitor's brand. I'm looking at upgrading it with a much nicer Linksys model.
