m_cstilly
Sep 19, 2016Aspirant
Slow wired connections
I have a WNR2000v4 connected to an 8channel, DOCSIS 3 surfboard modem hooked directly into my cable provider. My desktop sits right by the modem and router, so I have it wired into the router instead...
- Sep 21, 2016
So the hardware functions at speed less a reasonable amount of overhead when used as a switch. When operating as advertised the overhead is >50%. It's not under warrenty because Netgear's warranty and customer service periods are way below par for industry standard. I guess I'll be replacing it with a competitor's brand. I'm looking at upgrading it with a much nicer Linksys model.
ElaineM
Sep 21, 2016NETGEAR Employee Retired
Sounds like a hardware problem. If this is still under warranty, contact support and get an RMA.
m_cstilly
Sep 21, 2016Aspirant
- ElaineMSep 21, 2016NETGEAR Employee Retired
Sorry to hear that it didn't work for you.
Normally, this should have been resolved by uploading the latest firmware and doing a factory reset.
