mapper14
Dec 28, 2021Aspirant
Slow Wired LAN speeds
Is it at all possible for this older model WNR3500Lv2 to be configured to reach my ISP provider speed of 150 mbs? I've updated the firmware to latest, turned off QOS, all other settings default, but...
mapper14
Dec 29, 2021Aspirant
Michael,
Here's my configuration details:
I pay for a 150mbs service from the TELUS phone co here in Canada.
TELUS uses an Actiontec T3200M router configured to the Nokia fibre adapter box coming into my home.
If I connect my desktop computer directly to a LAN port on the Actiontec T3200M I get the full speed that I'm paying for (actually Ookla Speedtest say 170mbs or greater). On the TELUS Actiontec T3200M I have WiFi and DHCP diabled so that I can use it strictly as a bridge router to pass the ISP internet feed into the Netgear WNR3500Lv2 via one of its 1G LAN ports. I'm using the Netgear WNR3500Lv2 as my WiFi and DHCP address server.
So for my test I switch the ethernet connection on my desktop computer ethernet from the TELUS Actiontec T3200M into one of the Netgear WNR3500Lv2 LAN ports.
So then my speed as reported by Ookla Speedtest (same speedtest) drops to about 90mbs.
On the Netgear WNR3500Lv2 I've turned off all QoS, Parental control, Access control, port forwarding etc.
So this is a very direct comparison test. I can unplug all other ethernet feeds out of the Netgear LAN port to eliminate any possible external conflict on the home LAN, but it makes no difference, I still get 90mbs instead of the full 150 or greater.
So my question is: Where is the bottleneck that's throttling the speed on the Netgear, or is the Netgear not capable of passing through a 150mbs signal, applying DHCP and feeding it to my desktop via one of its LAN ports?
-Mike
michaelkenward
Dec 29, 2021Guru - Experienced User
The Actiontec T3200M is a "Bonded VDSL2 Wireless AC Gateway Router".
T3200M - MoCA 2.0 Bonded VDSL2 802.11ac vectoring G.fast/PON 4 Port GigE - Actiontec.com
So "bridge mode" is the right thing to do if you want to use the WNR3500Lv2 as a router. But that raises the question, what do you want the Netgear WNR3500Lv2 for? As you said earlier, it is pretty old, from 2011.
Why use it as your "WiFi and DHCP address server" when the Actiontec is likely to be a lot better?
Unlike the Actiontec, the WNR3500Lv2 doesn't have 5 GHz wifi. You don't say If your Ookla tests are done over wifi. If so, 90-95 Mbps is pretty good.
Your subject says, "Slow Wired LAN speeds". A four-port 1000 Mbps switch, the smallest on offer, costs next to nothing. If the idea is to use the WNR3500Lv2 to give you wider wifi coverage, you would do better to work out how to put that into access point mode and to use the Actiontec as the router.
