zakk87
Feb 01, 2017Aspirant
Slow Wired Speed JNR3210
I noticed something very odd today, and I dont get it. When my desktop pc is wired into the router I get ~41Mbps download speeds, and ~4 Mbps upload. When I plug my desktop directly into the mode...
- Feb 06, 2017
Now I'm using openDNS and I add a blocked domains to blacklist. Router works with full speed.
I wait for ASUS RT-N18U whith has a native Prinserver. No more stupid Netgear USB Control App.
Maybe in future I buy again a Netgear product but for now thank you for (no)support.
Best regards
zakk87
Feb 02, 2017Aspirant
Thanks for the reply. Today I reset the unit 30-30-30 but after restore my config again slow speed. So I reset to factory again, and after on a firewall speed slow down and I cant go into GUI. Now I'm trying WNR3500L v2 with tomato by shibby and Works good with qos and firewall. Very weird but jnr3210 has a 620MHz CPU and 3500l 480MHz but Mipsel.
I must change the router, because 3500L has a bad wifi coverage.
- ElaineMFeb 02, 2017NETGEAR Employee Retired
Sounds like a hardware problem.
- zakk87Feb 02, 2017Aspirant
It's not a hardware problem. I found a BUG in software. When I add a keyword to "block sites" speed down to 40Mbps. So sad :( I test it few times. Red arrow is block site keyword enabled, blue arrow it's after clear list.
- ElaineMFeb 03, 2017NETGEAR Employee Retired
Unfortunately, that model is already EOL. There will be no future firmware updates that will be released.
