ShynarEli
Nov 24, 2020Follower
Slower speeds from switch than direct connect with modem/router
Sorry not very literate on all of this. I will try to give as much information as possible. I have a 1Gig subscription with Centurylink. I have their router / modem - Model C3000Z I bought the GS3...
Nov 24, 2020Guru - Experienced User
You need to go
router/modem------->switch----->then devices.
From the way you described it, you're going switch------>modem/router
PC
- michaelkenwardNov 25, 2020Guru - Experienced User
As plemans says you need to get the right layout.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Switches - NETGEAR Communities
