Happilyretired's avatar
Apr 20, 2021
Smart Connect using EX6100v2 extender with non-Netgear Router from Comcast?
My EX6100v2 extender is up to date with the latest firmware version.  I've configured it to use "one wifi name" (the setting causes the extender to use the same SSID name for each band as the SSID us...
  • plemans's avatar
    Apr 20, 2021
    smart connect *should* work with the arris.
    In terms of performance, sadly that is one that you have to test and see how well certain locations/positions works. I usually tell people to test multiple spots before settling on one as objects in walls (hvac, plumbing, etc) can cause wireless blockage.
