MICK_KOZ
Nov 15, 2023Aspirant
Smart WiFi AC1750 R6400 ACCESS CONTROL SLOW DOWN BANDWITH BIG TIME!
Hi, new here.
SYSTEM:
WIN 11 HOME
CYBERPOWER PC INTEL 12 CPU
32GB
12GB VRAM
ROUTER:
LATEST FIRMWARE INSTALLED V1.0.4.128_10.0.104
MODEM
MOTOROLA 3...
- Nov 15, 2023
You're wanting an AC device?
Not an AX device?
What are you using it for that you need access controls?You can also check on amazon for netgear renewed devices.
michaelkenward
Nov 15, 2023Guru - Experienced User
MICK_KOZ wrote:
MODEM
MOTOROLA 3.1
Which one?
with AC turned on "Block all new devices from connecting" I can only get 150-200Mbs DOWN 23Mbs UP max.
Tested how?
Wifi? Wired?
MICK_KOZ
1. AC turned on with "Block all new devices..." (only accessible with AC turned on....
2. Tested using speedtest.net
3. Wired -1GB ethernet through switch...
Any ideas?
Thanks for responding...
Mick
