richjohn85
Apr 20, 2023Follower
SmartConnect by Netgear router.. Do I want it on?
I have gigabit by att with 15+ devices like smart plugs and a few computers. Why would or wouldn't I want to use this feature? Seems like a good concept but of course I want my Xbox using 5g while my...
Apr 20, 2023Guru - Experienced User
I would enable it for a couple reasons.
1. everything is moving to a mesh/single ssid network. Starting with a single ssid now means when you change routers in the future, you can reuse that same ssid and everything just reconnects when you update
2. ease of use. Most devices will auto-switch to the 5ghz if they're needing the bandwidth. It can usually take a couple days to figure out which band they end up on but the higher bandwidth ones tend to be on there
3. simplicity for others. My wife loves only having 1 network to have to work with. She doesn't have to worry what band to connect to or access point.
