richjohn85
Apr 20, 2023Follower
SmartConnect by Netgear router.. Do I want it on?
I have gigabit by att with 15+ devices like smart plugs and a few computers. Why would or wouldn't I want to use this feature? Seems like a good concept but of course I want my Xbox using 5g while my...
michaelkenward
Apr 21, 2023Guru - Experienced User
richjohn85 wrote:
Should I enable it? Why or why not Thanks for the advice.
Why do you ask?
Your answer might help to sharpen the already detailed answers that you have received.
For example, perhaps you are concerned about setting up Internet of Things (IoT) stuff, which can be troublesome with smart connect.
...I want my Xbox using 5g while my nest uses 2.4...
Leave it to them to work out what to do.
