cmulrooney
Oct 20, 2021Guide
SMBv2 on WNDR3400v2 for ReadyShare with USB drive
My USB drive attached to my N600 (understood that it's old) cannot be accessed from any Windows 10 PC in my home. I looked for information related to the error I am getting in Windows. I found: ...
- Oct 20, 2021
SMBv2 will not be added to this older router.
Something you can do is to enable SMBv1 in Windows which may help here.
Oct 20, 2021Guru - Experienced User
- cmulrooneyOct 20, 2021Guide
thank you! I was thinking that's where I was headed. figured that I'd check here first for options.
C.
- FURRYe38Oct 20, 2021Guru - Experienced User
đ
