j_fix
Dec 17, 2016Tutor
[Solved] WNDR4500 Using Same SSID for 2.4Ghz and 5Ghz
I coudn't find a solution for this by searching so I'm posting: Using firefox: (other browsers may work but this is what I used) 1. Log into to router on browser. 2. Select Wireless 3...
- Jan 31, 2017
I've tried from a different computer with a fresh install of firefox to try and figure out what the discrepancy could be.
On the original computer I had the "Toggle split console" screen option turned on (second on the left option of those small icons on the right hand side of the javascript debugger) - you can hover the mouse over them to see what each one does.
From the default install: try clicking on the icon that is titled "Console" 3rd from left and then type
cf.ssid_an.value = "Wanted"
Then click on the "Debugger" 4th from left option next to "Console" and push F8.
kerng
Feb 14, 2017Aspirant
I noticed this may be specific to WNDR4500 model. I have a WNDR4300 and it does allow me to specify the same SSID for both bands. Now whether that is really working or not, I don't know. Was this solution to get around not being able to even specify the same SSID for both bands in the admin config screens?
- curiousgeorge23Feb 16, 2017Aspirant
Yes, unable to enter same SSID for both bands was original issue but j_fix came up with great workaround.
