mgalgs
Jun 06, 2021Aspirant
Some domains related to cryptocurrency mining are blocked and possibly crashing my Orbi router
I've been having issues with my Orbi router blocking certain domains related to cryptocurrency mining, and possibly crashing my router. I've never been able to access getmonero.org from behind my rou...
- Jun 07, 2021
New thread under the correct category: https://community.netgear.com/t5/Orbi/Some-domains-related-to-cryptocurrency-mining-are-blocked-and/m-p/2103647
michaelkenward
Jun 07, 2021Guru - Experienced User
mgalgs wrote:
My model wasn't available in the dropdown menu above, but I have the RBK853 AX6000 (Amazon link). Main router plus 4 satellites.
It helps to post in the right section for your device.
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
- mgalgsJun 07, 2021Aspirant
Ah I see. The "Start a New Discussion" link from the forum home page takes you to the Nighthawk WiFi Routers.
I guess I shouldn't be surprised that the Netgear forums are a mess after experiencing the utter carnage of the Orbi software...
I'll move my post.
michaelkenward wrote:
mgalgs wrote:My model wasn't available in the dropdown menu above, but I have the RBK853 AX6000 (Amazon link). Main router plus 4 satellites.
Actually the model select options appear to be the same. Still no RBK853.
