articaine
Oct 17, 2016Aspirant
speed slow down
I installed the R6400 Saturday evening. My speeds wired from modem is about 70Mbps, and it was close to that speed with the 5ghz frequency, the 2.4Ghz is about 30-35. 2 evenings later, I notice the ...
- Oct 19, 2016
Hi articaine,
1. On both instances, it may be caused by wireless interference. You can use a WiFi analyzer app/program and change the channel for the wireless bands to the best available.
2. Does the issue persist on all your wireless devices?
3. Have you tried reflashing the firmware and resetting the router?
Dexter
Community Team
