prflip157
Nov 24, 2020Aspirant
SSID Broadcast
SSID for 2Ghz stopped broadcasting. I have restarted, turned off/on "Enable broadcast" and applied, but cannot see SSID as available wireless option. Need this as many home devices cannot connect t...
michaelkenward
Nov 25, 2020Guru - Experienced User
What do the LEDs show?
wcalifas
Nov 26, 2020Prodigy
Is there a button on the outside of the gateway that let's you turn on or off the wifi? If so press it for 5 seconds and see if that changes it, if not press it for 10 seconds if it has that button.
- prflip157Nov 26, 2020AspirantThere is a on off button at the back close to the coacts connection. I press that but that didn’t solve the issue.
