prflip157
Nov 24, 2020Aspirant
SSID Broadcast
SSID for 2Ghz stopped broadcasting. I have restarted, turned off/on "Enable broadcast" and applied, but cannot see SSID as available wireless option. Need this as many home devices cannot connect t...
prflip157
Nov 26, 2020Aspirant
All of the lights are lit.
wcalifas
Nov 26, 2020Prodigy
There should be a wifi button on off on top
- michaelkenwardNov 26, 2020Guru - Experienced User
wcalifas wrote:
There should be a wifi button on off on topBe warned. The wifi button is actually an LED that doubles as a switch.
You would not be the first person to be baffled by that.
The bugger is that you need to enable the wifi in the browser graphical user interface and check that the switch is on. Disable in the GUI and the button is useless.
If a;; the switches are on, them there is another problem somewhere.
- prflip157Nov 27, 2020AspirantTHANKS TO ALL WHO REPLIED!!
The “reset” button brought back the missing SSID broadcast...
Thanks again!!
