Jmztaylor
Feb 12, 2016Aspirant
Starting port number must be less than 65535
With this setting, I get that error message when applying. No matter what number I put in the port boxes it always errors out this way. WNDR3400V2 is the model number. On the latest firmwar...
Jmztaylor
Feb 17, 2016Aspirant
Actually, I found the issue. If you change the LAN IP address is when this issue occurs. If you change the third octet. And its impossible to change again without factory reset.
ElaineM
Feb 18, 2016NETGEAR Employee Retired
That's strange and that shouldn't happen.
I was able to change on mine no problems.
But glad to hear that you were able to save the settings.
