determs
Mar 16, 2021Aspirant
Static IP Address Not working on Satellites
I have a RBR50 [2.7.2.104] which has 4 satellites (RBS50x2 [2.7.2.104], RBW30x2 [2.6.2.2]). In order to help with supporting my routers I have set static IP addresses for satellites. After the...
determs
One thing I was wondering, maybe it was self-inflected? The static routes I had setup were part of the DHCP range...would that have created this issue? The printer didn't have problems, which is why I'm now wondering about my latest theroy.
antinode
Mar 16, 2021Guru
> [...] I have set static IP addresses for satellites. [...]
Real static addresses, not reserved dynamic addresses? Why?
Especially for a device like a satellite, which would be approximately
useless without the main router (and its DHCP server) working. Why buy
trouble?
> [...] The static routes I had setup were part of the DHCP
> range...would that have created this issue? [...]
"static route" and "static IP address" are spelled differently for a
reason.
Manually handing out addresses from the DHCP pool could certainly
cause problems. If you really want to use static addresses, then shrink
the DHCP pool, and use only ex-pool addresses for those static
addresses.
> The printer didn't have problems, [...]
Some of us non-psychics can't see any of your IP addresses, which
makes it tough to guess which devices might be affected first.
- determsMar 17, 2021Aspirant
After all of this I have realized that this is due to the other DNS issues that we are having on the Orbi ... see other posts.
https://community.netgear.com/t5/Orbi/Orbi-DNS-and-DHCP-and-NTP-Broken/m-p/2070961
