lafoutloud05
Jun 04, 2018Follower
Static IP slow, Mac OS
Hi There,
Hoping someone can help. I work for a nonprofit where I'm basically IT, management, help desk....all the things. I'm usually pretty computer savvy with most basic things, but having s...
- Jun 07, 2018
Hi lafoutloud05,
Welcome to the community!
1. What is the firmware version of the router?
2. Please try selecting the option "Use Default Address" for the Router MAC Address portion then Apply.
3. Does bypassing the router and connecting your Mac computer with the static IP configuration yield the same result?
Dexter
Community Team
DexterJB
Jun 07, 2018NETGEAR Moderator
Hi lafoutloud05,
Dexter
Community Team
- DexterJBJun 11, 2018NETGEAR Moderator
Hi lafoutloud05,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
