synoptics
Nov 29, 2015Guide
Static routes with WNR3500Lv2
I'm having a problem with devices on a non local (192.168.0.x) subnet reaching the Internet via the WNR3500Lv2. The Firmware Version is V1.2.0.34_40.0.75. My configuration is a follows. First, I don'...
- Dec 10, 2015
TheEther I finally have a solution for my issue. I loaded "Tomato v1.28.0000 MIPSR2-132 K26 USB AIO" firmware and everything I need now seems to work fine. Nice piece of software. Lots of features over the stock Netgear firmware. I like that it's linux based and you can ssh to manage it.
I did hear back from engineering. The capability to NAT/route non-local subnet traffic was specifically removed. They were concerned that requests for features (port forwarding, DoS protection, etc.) for stuff that was non-local would complicate things for a configuration that few people had. Maybe it's a Broadcom chip issue. We'll see. I'll do some testing.
Thanks for your help on this issue.
TheEther
Nov 29, 2015Guru
I wouldn't worry about the Private setting. It just controls whether the route is advertised whenever RIP is enabled.
I suspect the problem is that the WNR3500Lv2 is not performing NAT on traffic from the 192.168.0.0/24 subnet. You say that things worked with your WGR614v9. Were you using the same subnets (i.e. 10.120.102.0/24 and 192.168.0.0/24)?
I once tried to help another user with this same problem by suggesting that he subnet his main network into two parts, with the second part being a more-specific subnet of the first. My thinking was that this would enable the router to perform NAT for traffic coming from either subnet.
Let's keep your main subnet, 10.120.102.0/24, the same. Replace the 192.168.0.0/24 subnet behind your cisco with a new subnet, 10.120.102.128/25. Notice how this is a more-specific subnet of 10.120.102.0/24. You can keep 10.120.102.9 as the IP address for the cisco on the main subnet. On the other side of the cisco, configure it with IP address 10.120.102.129. This would be the default gateway for that subnet. On the WNR3500Lv2, configure a static route to 10.120.102.128/255.255.255.128 to point at 10.120.102.9.
Unfortunately, the other user reported that this trick didn't work. If you are willing to give it a shot, I'd be interested in knowing whether it works. I can't think of any reason why it wouldn't.
synoptics
Nov 29, 2015Guide
Thanks for your help.
"I suspect the problem is that the WNR3500Lv2 is not performing NAT on traffic from the 192.168.0.0/24 subnet. You say that things worked with your WGR614v9. Were you using the same subnets (i.e. 10.120.102.0/24 and 192.168.0.0/24)?"
This is my suspicion (not performing NAT correctly on the 192.168.0.0/24 subnet traffic) as well. Just to verify, I re-installed my old WGR614v9 router with the same configuration (i.e. 10.120.102.0/24 and 192.168.0.0/24 subnets) and it does work correctly. I'd try your suggestion of using a more specific subnet of 10.120.102.0/24 but this subnet contains a cluster of openstack servers and reconfiguring would be a challenge. I'll check with tech support tomorrow. This has to be a bug. I don't know why you would support static routes and not NAT the traffic from those networks especially since it was supported in older products. Hopefully they will have a solution.
- TheEtherNov 29, 2015Guru
I would appreciate a follow-up once you hear from Netgear. I'm curious whether they deliberately removed this functionality or if it's a bug.
- synopticsDec 01, 2015Guide
Stay tuned. I am getting the run around from tech support. I'm now told I need a ProSAFE business class router to get the functionality I had in my old WGR614v9. Just finished a chat with ProSAFE pre-sales. They said the FVS318G V2 should NAT non-local IP subnet traffic to the WAN port. I'll buy a FVS318G V2 and see. Will update this thread when I have an answer.
- TheEtherDec 01, 2015Guru
It's too bad they won't give you a straight answer about NAT support on the WNR3500Lv2 or any consumer-grade Netgear router. Perhaps a moderator can check directly with Engineering. Specifically, the question is, will the current generation of consumer-grade Netgear routers perform NAT on other local subnets besides the directly attached subnet? In other words, will traffic from subnet B going to the Internet be NAT'd?
Internet-----Netgear router------Subnet A-------Another Router--------Subnet B
- synopticsDec 10, 2015Guide
