synoptics
Nov 29, 2015Guide
Static routes with WNR3500Lv2
I'm having a problem with devices on a non local (192.168.0.x) subnet reaching the Internet via the WNR3500Lv2. The Firmware Version is V1.2.0.34_40.0.75. My configuration is a follows. First, I don'...
- Dec 10, 2015
TheEther I finally have a solution for my issue. I loaded "Tomato v1.28.0000 MIPSR2-132 K26 USB AIO" firmware and everything I need now seems to work fine. Nice piece of software. Lots of features over the stock Netgear firmware. I like that it's linux based and you can ssh to manage it.
I did hear back from engineering. The capability to NAT/route non-local subnet traffic was specifically removed. They were concerned that requests for features (port forwarding, DoS protection, etc.) for stuff that was non-local would complicate things for a configuration that few people had. Maybe it's a Broadcom chip issue. We'll see. I'll do some testing.
Thanks for your help on this issue.
TheEther
Dec 05, 2015Guru
You can try sniffing the traffic using Wireshark.
- synopticsDec 05, 2015Guide
I thought about that, but the FVS318Gv2 doesn't support port mirroring and I don't have a network TAP.
- ElaineMDec 07, 2015NETGEAR Employee Retired
synoptics Did you include a default route on the switch?
0.0.0.0/24 then the Default gateway will be the IP address given by the FVS318Gv2.
- synopticsDec 07, 2015Guide
Yes. A default route exists on the layer-3 swtich pointing to the default gateway address on the FVS318Gv2. Even though I'd like to see this functionality on the WNR3500Lv2, I have started a new thread over in the VPN Firewalls section.
