Inetwl
Jan 12, 2023Aspirant
Static Routing on Netgear R6220
I need to connect LAN A to LAN B with static routing. Router 192.168.A.1 should be able to send packets to router 192.168.B.1, even though each has its own ISP. I should be able to use the followin...
michaelkenward
Jan 12, 2023Guru - Experienced User
I fear that this will not work. From earlier discussions here, it seems that you can't join two networks with different WAN IP addresses. They are two separate networks.
You probably need some other way to "tunnel". I would suggest ReadyCLOUD, but his is on its way out. and may not do what you want.
Perhaps you could explain what it is you want to do on this connection so that someone more knowledgeable can advise.
- InetwlJan 12, 2023Aspirant
That is the answer I expected. I will look into ReadyCLOUD and its replacements to see whether there may be other answers.
- michaelkenwardJan 13, 2023Guru - Experienced User
Don't get hooked on ReadyCLOUD. It is on its way out.
Over time, Netgear has removed various features, usually on the grounds of security.
You may have to find some sort of third party option.
I do not know what you want to do, but cloud storage is a good way of sharing data.
