Inetwl
Jan 12, 2023Aspirant
Static Routing on Netgear R6220
I need to connect LAN A to LAN B with static routing. Router 192.168.A.1 should be able to send packets to router 192.168.B.1, even though each has its own ISP. I should be able to use the followin...
Inetwl
That is the answer I expected. I will look into ReadyCLOUD and its replacements to see whether there may be other answers.
michaelkenward
Jan 13, 2023Guru - Experienced User
Don't get hooked on ReadyCLOUD. It is on its way out.
Over time, Netgear has removed various features, usually on the grounds of security.
You may have to find some sort of third party option.
I do not know what you want to do, but cloud storage is a good way of sharing data.
