rkrzewski
Jul 08, 2016Guide
Static routing: problem reaching host on local network from router's WAN side
I'm having trouble setting up routing in a small office network. I've prepared a diagram of the topology https://drive.google.com/file/d/0B0PjGlcEN6DDV3BpNHJWTEdaWmM/view Few words of explainatio...
- Jul 08, 2016
Do you have port forwarding set up? Otherwise, how can A get past the firewall on the WNDR4300?
I suspect there are two things working against you.
- WNDR4300 is performing NAT, so it's going to rewrite IP addresses.
- Stock firmware will only NAT IP addresses on its directly connect subnet. In your case, it will not NAT 192.168.123.0/24 traffic.
You should install DD-WRT on your WNDR4300. Then you can disable NAT and operate it as a pure router.
rkrzewski
Jul 08, 2016Guide
You are right. I do have port forwarding set up for TCP/22 -> 192.168.1.10:22. This is the reason of destination IP rewriting I didn't understand.
I don't need or NAT or firewalling bewneen LAN and WAN interafaces of WNDR4300 because it's located inside a trusted network (except WiFi access, of course). If I understand correctly stock firmware won't allow me to do that. Welp, time to read up on DD-WRT then :)
Thanks a lot for your help!
TheEther
Jul 08, 2016Guru
If you don't need your WNDR4300 to operate as a router, then convert it to an AP. This will eliminate the 192.168.1.0/24 subnet. Update A's static route for 192.168.123.0/24 to point directly at B.
The easy way to enable AP mode is to use ADVANCED > Advanced Setup > Wireless AP. Tip: Ignore the instructions and avoid the WAN port. The WAN<->LAN path is very slow.
- rkrzewskiJul 11, 2016Guide
I certainly don't need WNDR4300 to operate as firewall / NAT, but I think I'd still need to use it as a router to direct the traffic from machines connected to the wireless network to C via B.
Would "Static routes" setings be applicable in Wireless AP mode? Otherwise the packets would leave the AP on the default route to A and then would be routed back towards B, which is suboptimal.
Second question: would WNDR4300 in Wireless AP mode be able to act as DHCP server for a segment of 192.168.2.0/24 or not? I'm running dnsmasq on A, so I could work around that if necessary.
- TheEtherJul 11, 2016Guru
rkrzewski wrote:I certainly don't need WNDR4300 to operate as firewall / NAT, but I think I'd still need to use it as a router to direct the traffic from machines connected to the wireless network to C via B.
As an AP, the WNDR4300 operates as a switch. So, server B's eth0 interface would be on the 192.168.2.0/24 subnet. Suppose you change the address for B:eth0 to 192.168.2.10. Then update the static route on A to 192.168.123.0/24 -> 192.168.2.10.
Would "Static routes" setings be applicable in Wireless AP mode?Static routes are not applicable on the AP itself, but you still need one on A, as I described above.
Yes, this is true, but A will send an ICMP redirect back to the wireless client with information that C is reachable through B. Wireless clients will subsequently send traffic for C directly to B.
Second question: would WNDR4300 in Wireless AP mode be able to act as DHCP server for a segment of 192.168.2.0/24 or not? I'm running dnsmasq on A, so I could work around that if necessary.DHCP server is not supported in AP mode with Netgear firmware. It is supported with DD-WRT. If you want to avoid the ICMP redirect process, then you can use a DHCP server.
- rkrzewskiJul 12, 2016Guide
I've switched WNDR4300 do Wireless AP mode and it worked great! :) I have full now connectivity between all hosts.
DHCP is not a problem. As I wrote before I'm running Linux on the servers and setting up DHCP using dnsmasq was very simple.
I didn't know about ICMP redirect, or maybe I did know about it once when I took TCP/IP networking class at Uni some 15 years ago :)
I also tested your suggestion to plug the Ethernet cable between A and WNDR4300 to LAN rather than WAN port but I've observerd a little oddity: When A is plugged into LAN port, and WAN is left unconnected, I cannot access the administrative interface of WNDR4300 or even ping it's IP address, but otherwise the network works fine. When A is plugged into WAN port, I can access the admin interface normally. I've checked DHCP server's logs that the router requests the same IP address in both cases, presenting the same MAC address. This is a minor nuissance though, because I hope not to spend too much time accessing the administrative interace :)
Thanks a lot for your assistance!
