AvidMCUser123's avatar
Jan 19, 2018
Stuck on Login
I am trying to update my Firmware. I am locked out of the Routerlogin.Net site.
It keeps asking for my Username and Password. Nothing I try works.
What Username and Password are they asking for?
  • > What Username and Password are they asking for?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Types of Logins".
       If you're talking to the router's own web site (which is what
    routerlogin.net should get you), then the defaults are "admin" and
    "password", but these could have been changed.  If the defaults don't
    work, and you can't guess anything better, then you may need to reset
    the thing.  Which means that you'd also need to reconfigure it.
