hondadude1981
Apr 29, 2026Follower
Successor to WNDR 3800/4300 and 6300 WNDR?
Can anyone provide the current Netgear router models that are the successor units to WNDR 3800/4300 and 6300 WNDR? I am looking for the newest router successor models that also receive periodic se...
CrimpOn
Apr 29, 2026Guru - Experienced User
Netgear's home WiFi routers are here:
https://www.netgear.com/home/wifi/routers/
WiFi6 products are the obvious successor models, and are generally less costly than the subsequent WiFi7 models.
A significant consideration is the speed of the Internet Service Provider connection. (ISP) Newer (and more expensive) models support higher than gigabit connections.
Another consideration is the sort of devices to be connected on the LAN. Once again, lower cost products have only gigabit Ethernet connections, while the more expensive products allow for higher speed connections.
