hondadude1981
Apr 29, 2026Follower
Successor to WNDR 3800/4300 and 6300 WNDR?
Can anyone provide the current Netgear router models that are the successor units to WNDR 3800/4300 and 6300 WNDR? I am looking for the newest router successor models that also receive periodic se...
May 04, 2026Guru - Experienced User
What performance goals do you have with this device? Those are pretty ancient devices. Several generations behind.
So what are you trying to achieve for usage and whats you're budget? And the size of the home?
Pretty hard to recommend much when you're asking about devices that old to upgrade.
