Seekerrrrr
Jan 09, 2021Follower
Suggestion, 6120 or 6220
Hi, I am trying to help some students get through their online classes,who don't have a wifi connection. The strength of the class is around 13-15 devices, which router should I use to get an uninterrupted access? R6120 or R6220 or if there is some other budget option? Please specify the model, thanks!
1 Reply
> [...] which router should I use to get an uninterrupted access? [...]
To what would you be connecting this router?
> [...] R6120 or R6220 or if there is some other budget option? [...]
I'd avoid the R6120.
https://community.netgear.com/t5/x/x/m-p/1939906
I don't do enough comparison shopping in this stuff to know enough
about what's good or reasonably priced. And I wouldn't limit myself to
Netgear, either.
