kelley2100
Nov 30, 2015Aspirant
switched computers, now router won't work, this device is blocked by access control in the router
Hello, I have had this wireless router for about three months and it worked fine. The main computer it was set up on is about 7 years old. I have a new computer which was added to the network without...
- Retired_MemberDec 01, 2015
I would start over only because it's easier than guessing what you did at some point. Push reset until power led flashes and use defaults found on router label. Locate the manual and read it too to gain a better understanding.
Retired_Member
Dec 01, 2015I would start over only because it's easier than guessing what you did at some point. Push reset until power led flashes and use defaults found on router label. Locate the manual and read it too to gain a better understanding.
kelley2100
Dec 08, 2015Aspirant
Thanks for the suggestion. Netgear Support gave me the same advice and it worked. Thanks for your help.
