BluStu59
Apr 28, 2020Tutor
Switching to 2.4 GHZ on a dual band
Does anyone know if I can set the R6220 dual band router to 2.4 GHZ only? I have a Google Mesh System at the moment and I need a separate network using 2.4 GHZ only and google will not allow that. ...
- May 01, 2020
Forget the password recovery unless it was set-up before - you will end in a dead end loop.
Do a factory reset, and login using admin and password.
BluStu59
May 01, 2020Tutor
Thanks for the info my friend, I'll give it a shot when I get home.
antinode
May 01, 2020Guru
> It[']s unfortunate that you decided to answer this thread in the way
> that you have. [...]
From the first reply:
> [...] Get the User Manual. Read. Look for "Control the Wireless
> Radios".
Did you? I'll admit that I was too lazy to post an annotated picture
of the referenced page. I'm accustomed to dealing with grown-ups who
can read a book by themselves. Sorry.
