BluStu59
Apr 28, 2020Tutor
Switching to 2.4 GHZ on a dual band
Does anyone know if I can set the R6220 dual band router to 2.4 GHZ only? I have a Google Mesh System at the moment and I need a separate network using 2.4 GHZ only and google will not allow that. ...
- May 01, 2020
Forget the password recovery unless it was set-up before - you will end in a dead end loop.
Do a factory reset, and login using admin and password.
BluStu59
May 01, 2020Tutor
I've been trying to log into the rounter via http://www.routerlogin.com I used the default admin and password to log in but its rejecting the sign-in. I then entered the serial number for the back of the unit and the responce I get is invalid serial number. I took the number from the underside of the rounter. I'm now stumped (again) Any thoughts?
schumaku
May 01, 2020Guru - Experienced User
