jaaytech
Mar 06, 2016Aspirant
Synology VPN PPTP server constantly dropping connection in short time (using wndr3700v3 router)
Hi, first of all, my english is poor, dont punish me. router wndr3700v3 (latest firmware) NAS synology ds214 (latest OS) synology VPN PPTP server (no encrypting, authentication MS-CHAP v2) n...
ElaineM
Mar 07, 2016NETGEAR Employee Retired
jaaytech How is the VPN client connected (wired or wireless)? You may verify if the router is causing the problem by bypassing it. Another option is to lower down the MTU on the router.
jaaytech
Mar 08, 2016Aspirant
hi, just additional informations from my troubleshooting, i have tested connection stability with another VPN (my friend provided his for test purposes) and it working perfectly, so this excluded any issue on client side.
Now back to Elaine suggestion, client side is connected on wifi and router side is connected by wire in cascade with technicolor 2700 (bridge mode) ,default values of MTU size was 1400 in case of router and 1500 for VPN server settings, i have already tried to setup to the same value (1400) and it didnt help. So iam going to try lower values, i will provide feedback in few minutes. Thank you.
Milan
