jaaytech
Mar 06, 2016Aspirant
Synology VPN PPTP server constantly dropping connection in short time (using wndr3700v3 router)
Hi, first of all, my english is poor, dont punish me. router wndr3700v3 (latest firmware) NAS synology ds214 (latest OS) synology VPN PPTP server (no encrypting, authentication MS-CHAP v2) n...
jaaytech
Mar 08, 2016Aspirant
hi, just additional informations from my troubleshooting, i have tested connection stability with another VPN (my friend provided his for test purposes) and it working perfectly, so this excluded any issue on client side.
Now back to Elaine suggestion, client side is connected on wifi and router side is connected by wire in cascade with technicolor 2700 (bridge mode) ,default values of MTU size was 1400 in case of router and 1500 for VPN server settings, i have already tried to setup to the same value (1400) and it didnt help. So iam going to try lower values, i will provide feedback in few minutes. Thank you.
Milan
jaaytech
Wow, i wuldnt believed that the MTU size can so rapidly affect stability, it was the issue whole time. Now i just will find optimal MTU size (1200 works fine, but is more fragmented). Thank you for your time. You are best !
Milan
