corvairbob
Jan 28, 2020Tutor
tell me does this sound correct c7000 modem router
ok i got this modem last week and it took some time to get it connected to comcast. after about 2 hours they did it. turned out i was told it was new in the box but it must have been a return and was...
- Jan 28, 2020
corvairbob wrote:thanks
so tell me if i do not actually have devices that need the extra channels they may not even turn on then? the download channels may just turn on by default, but maybe i do not have devices that are asking for those extra channels? just wondering.
the channels locking are a combination of whatever your ISP has setup for your partioning/the cmts/and the signal strength. upload speeds aren't nearly the same as download so 3 channels is sufficient to saturate your upload speeds in most cases. Even my gigabit only has a 35mbps upload which a single channel could saturate.
corvairbob
Jan 28, 2020Tutor
thanks
Jan 28, 2020Guru - Experienced User
