Gijoe37
Dec 05, 2021Aspirant
The access control of my SXR80 will not unblock my new Ubiquiti US-24 switch
I use access contol (block all new devices) and allow them as i connect new devices. the router will not unblock the Ubiquiti switch. If i change the access contol setting to allow all new devices ...
Gijoe37
I thought i should add that the switch is connected to a wired port on the main router.
- michaelkenwardDec 06, 2021Guru - Experienced User
The Orbi SXR80 is not one of the General WiFi Routers (Non-Nighthawk and Non-Orbi) devices covered in this section. (The Non-Orbi bit is a giveaway.) It isn't even a standard Orbi devices.
A lot of questions are generic and apply to most routers. In this case, I wouldn't be confident about that.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi Pro - WiFi for Small Business - NETGEAR Communities
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
