Mr_Smith
Sep 03, 2025Aspirant
The IP address conflicts with the WAN IP subnet
Old thread yes I know, but I recently solved this myself through some troubleshooting, as I had the same issue.
In the "internet setup" page in settings, do you have any LAN IP's entered in your DNS servers? i.e. do you have primary DNS set as your LAN IP of the router, or any other internal devices like a DNS server on your LAN?? This problem should not exist, but I guess its just a bug in the programming or an oversight in the router firmware, but try changing DNS servers to something external like 1.1.1.1 and 8.8.8.8, THEN try modifying your LAN config, you might find that the error message no longer exists.
We presume you are referencing this post?
User never came back to give feedback or final results. Hopefully was resolved back then.
FYI, best to make a new post and include a link to any referenced old posts in the new post.
Thank you for your feedback.Enjoy.
- Mr_SmithAspirant
Ah thanks! I made a separate post in case it may be helpful to others, as it was the solution to the problem for me.
