Retired_Member
Sep 17, 2021The login/psw (admin/password) does not work for readyshare.
I have had a Seagate portable drive connected to my R6400 netgear router for months and backing up with Time Machine on my MAC. I am not sure what happened but it stopped recogizing the R6400. I ta...
Retired_Member
Sep 18, 2021Here are the instructions:
https://kb.netgear.com/21360/How-to-setup-Time-Machine-with-your-NETGEAR-router
michaelkenward
Sep 18, 2021Guru - Experienced User
Forgive me if I don't spend time chasing up your link. But it seems that you are using "Time Machine", whatever that is.
Perhaps you need to talk to the people who provide that. Or you could answer the questions I asked.
"Can you access the router's graphical user interface (GUI) in the usual way?"
That deals with attaching a USB drive to a Netgear router. Troubleshooting other stuff is down to the people who created it.
If you are lucky an expert in "Time Machine" will step in.
- Retired_MemberSep 18, 2021
Oh thanks so much anyway. The problem is between Time Machine and Netgear because the instructions are for an external drive connected to the netgear router. FYI:
With Time Machine, you can back up files on your Mac that weren't part of the macOS installation, such as apps, music, photos, and documents. When Time Machine is turned on, it automatically backs up your Mac and performs hourly, daily, and weekly backups of your files.
- michaelkenwardSep 18, 2021Guru - Experienced User
Ah. Now I see. I have no idea what sort of external drive Time Machine expects to see. (Is that some sort of Mac utility?) ReadySHARE provides something that appears as a mapped drive on your network.
If you can work out how to see the USB drive attached to the router on a computer on your network, that would confirm that it is properly configured in the router. As a Windows user, I have no idea how this works on Macs. But my inclination would be to keep Time Machine out of the picture until I know the USB drive is behaving itself.
Some Netgear manuals talk about configuring for Time Machine, but the MR60 is not in there. But I did find this:
How to setup Time Machine with your NETGEAR router | Answer | NETGEAR Support
Then there is this:
I have no idea if any of that helps.
A word of warning, Netgear is steadily removing ReadySHARE features from the firmware in its routers, especially anything that depends on Cloud services.
Sometimes Netgear says it is for security reasons at others it is to make room for a service that it wants to sell. The release notes for firmware usually warn when this is happening. I have no idea if that includes whatever allows Time Machine to work.
- Retired_MemberSep 19, 2021
Thank you very much for your assistance. The first link is actually the same one I sent to you that calls for the username/password of admin/password. This used to work. I believe it is netgear that changed something with readyshare and this will probably never work again.
I tried the instructions in the 2nd link but it will not recognize the hard drive connected to the router.
The good news is that I can connect the hard drive directly to my MAC and get a backup through Time Machine so I will have to do that once a week or so.
Thanks again. I truly appreciate your time and expertise.
