LBryan
Dec 30, 2021Follower
The modem has blinking amber upstream but no other lights are on.
Only the power and the upstream light is on for the modem, the upstream light is blinking amber. I am seeing WiFi being provided to my mobile devices but when using WiFi nothing actually loads. I’ve a...
Dec 31, 2021Guru - Experienced User
Do you have a screen snip of the modems cable connection page and event logs?
Also, check your coax line for kinks, damage, old/bad/cheap/loose/corroded connections. Replace them if there are.
Remove any splitters, amplifiers, or signal attenuators from your line.
