Durgarru
May 09, 2019Tutor
The v1 firmware uploaded to R6400v2
Hi,
I have a problem with my Netger R6400v2 router. By mistake I've uploaded the firmware for the v1. I've tried to upload the correct v2 firmware via TFTP (using tftp2.exe, tftpd64 and Windows...
- May 11, 2019
I found the guide where was explained how to flash router with nmrpflash. Not that hard to perform as I thought. :)
Durgarru
May 09, 2019Tutor
1. The router act normal (all of the LED are white). I can connect with the internet and use it (with cable and via Wi-Fi).
2. In tftp2.exe I recieved "Unable to get responses from server." message; In tftpd64 when I click "PUT" button, "block#0" appeared but nothing happend; In Windows cmd tftp i recieved "Connect request failed" message. Each time I turn off and on the router (with reset button holding at the back) before I proceed with the upload the firmware. (I bind the IP adress too). After that the router boot normal and is usable but still with the v1 firmware.
3. I can get acces to GUI via web browser. It looks like the one from the v2 firmware but there is caption said its R6400 (not R6400v2). When I try to upload from my hard drive the v2 firmware through "Router update" after a few seconds the GUI respond with that message: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.".
To sum up: my router works normal, I can connect with ethernet cable and Wi-Fi. I've tried three different tftp methods, all of them fail.
I think the tftp might help but I dont understand when I have to proceed with the upload during restart.
antinode
May 09, 2019Guru
> 2. In tftp2.exe [...]
I'd forget the fancy third-party programs, and stick to the built-in,
simple, command-line TFTP client program. In any case, you need to
configure the network interface on your computer with a static IP
address (et c.), which steps you haven't mentioned.
> [...] (I bind the IP adress too). [...]
Not a very detailed description of anything.
> [...] "This firmware file is incorrect! [...]
If the firmware is too smart to let you load firmware for a different
model, then the TFTP scheme may be your best bet.
Do you ever see the Power LED flashing as it says in those KB
articles?
What happens if you ignore the Reset button when you start the thing?
> [...] I think the tftp might help but I dont understand when I have to
Whenever it works? Some experimentation may be needed.
- michaelkenwardMay 10, 2019Guru - Experienced User
Just one thing to add that has not come up already, there is a more thorough "recovery reset" that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
This is something that Netgear sometimes requires when people are doing fancy stuff in beta tests.
I am surprised that you managed to force the wrong firmware on to the device. The process usually fails because the update process is smart enough to spot the mismatch. Are you sure that it took? After all, your router is still working.
- DurgarruMay 11, 2019Tutor
I figured it out. Thanks guys for your help.
- michaelkenwardMay 11, 2019Guru - Experienced User
Durgarru wrote:
I figured it out.
That's good news.
Care to tell us what worked for you? It might help someone who turns up later with a similar issue.
