Durgarru
May 09, 2019Tutor
The v1 firmware uploaded to R6400v2
Hi,
I have a problem with my Netger R6400v2 router. By mistake I've uploaded the firmware for the v1. I've tried to upload the correct v2 firmware via TFTP (using tftp2.exe, tftpd64 and Windows...
- May 11, 2019
I found the guide where was explained how to flash router with nmrpflash. Not that hard to perform as I thought. :)
michaelkenward
May 11, 2019Guru - Experienced User
Durgarru wrote:
I figured it out.
That's good news.
Care to tell us what worked for you? It might help someone who turns up later with a similar issue.
Durgarru
May 11, 2019Tutor
- michaelkenwardMay 11, 2019Guru - Experienced User
Interesting that nmrpflash worked where TFTP failed.
Looks like you have added the R6400v2 to the list of those known to work.
