Innocentpro's avatar
Dec 01, 2020
There is no port forwarding option on my Netgear extender
Hi, so ive been trying to do somethinng with port forwarding but i cant find the option on my netgear extender. I have a main D link router, which then connects to another d link router that acts as an extender. Then comes the netgear extendor  that connects to the second router. Im trying to do the same portforwarding i did with my main router but now on my netegar extender exept i cant find the portforwarding option in the extendors website. On google it says go to advanced options then it will be somewhere there but its not for me.
  • antinode's avatar
    antinode
    Dec 01, 2020
    > [...] i cant find a port forwarding option. [...]
       There isn't one.  An extender does not do port forwarding.  A NAT
    router (like, for example, your main router) does port forwarding.
  • > [...] ive been trying to do somethinng with port forwarding but i cant
    > find the option on my netgear extender. [...]
       It's an extender, not a NAT router.
    > [...] Im trying to do the same portforwarding i did with my main
    > router but now on my netegar extender [...]
       Why?  Why not do it on your (unspecified) "D link router" (where it
    might be possible)?
    > [...] On google it says [...]
       Thanks for the helpful link.  Think, for a moment, about how little
    useful information that non-description conveys to the non-psychics in
    your audience.
       General advice: Your stuff would be easier to read if you used some
    apostrophes.  For example, "cant" is a word, different from "can't".
    • Innocentpro's avatar
      Innocentpro
      Tutor
      I actually did not understand anythign at all from what your'e saying. But i'll try to understand you're question's.
      I attached a screenshot, thats the menu i have. I searched thrugh all of the components on the left side but i cant find a port forwarding option. To explain the router stuff agian, I have 2 router's that are the same brand and model. But 1 acts as the main router where all the internet starts and is connected to the modem (not sure what you call the device but it has to be there for the router to work). The second one is literally the same brand and model but my ISP made it act as another network access point or basically an extender. The third device i have is the netgear wn2500 that I am talking about. I made some port forwarding changes on my first and main router but i am asking if i could do the same with my netgear device but the option "port forwarding" is not even on the list. See the screenshot. Your'e question and answer are very hard to understand.
      • antinode's avatar
        antinode
        Guru
